riceman
RC-Monster Gold
riceman's Avatar
10.15.2007, 05:30 PM
I wanted to put this up when I initially posted but had to make sure to get the okay from Tekno
The owner of Tekno was running at a local club race last weekend and I was able to get some video of his Revo running in the truggy class. My favorite part is where the nitro guys are starting and fueling up and the BL Revo is just sitting on the starting grid well, that and also where the truggy guys crumble under the pressure of getting chased down by a REVO!
Originally Posted by Serum View Post
erh.. They can't have enough testing time on that one! a neu 2.5d on a mamba maxx? they would be the first who run that setup succesfull
As for testing time with the Mamba Max / Neu configuration here is another clip I put together and posted up on Youtube in May - over five months ago.
Originally Posted by rc10mike View Post
Looks like a 1515 type may have issues hitting the a-arm.
He has the 1515 in there now and there are no issues with the a-arms. At maximum travel the a-arm does not hit the motor.
At first glance it looks very nice. I do have a problem with the mesh adjustment though. The stock Nitro motor sits a bit under the spur gear, so the angled up/down adjustment of the stock setup works well. However, the Techno mount makes the pinion sit to the side of the spur. The stock mesh adjustment will still work, but won't have the adjustment range that Mike's mount does by far.
The 5mm shaft requirement is not a real limitation because you can get bore adaptors. The new bore reducer line-up Mike has are really nice and strong.
The battery tray is nice though, but should be 6061 IMO simply for strength.
Not sure about the mesh issue but he has run different size Traxxas spurs and CBs. So it will accommodate those for sure. As for the battery tray I believe they considered aluminum but went with plastic to reduce weight and keep cost down. The plastic used is plenty durable. He's running a 3S 2P 8000 Maxamps pack in those videos. Almost half a year of testing and the prototype has not broken.
