10.20.2007, 03:50 PM
It will if you can gear low enough where it doesn't cogg. Even then, that's still too close to the "cogg-threshold" for my liking. You can help this by increasing start power and throttle control.
Besides the 2.5d is 1700kv if I'm not mistaken. Running at 4s (the MM max), that's only ~25krpm. To get any speed, you'd need to gear higher, which is pretty much opposite from you want to do.
I would suggest getting a higher kv Neu motor shooting for ~40k rpm @ 14.8v (kv between 2500 and 2700) and gear down.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.20.2007, 04:13 PM
I find this odd that this question is still being asked. There should be a sticky thread made this kind of stuff... what equipment will work with what.
