DrKnow65
DrKnow65's Avatar
10.21.2007, 01:26 PM
Heatsinks could be a mute point if the capacity of the board/fets are sufficient right? but by weight what weighs less to do the same work, a small board that performs well with a sink and fan- or a large board that does the same work with minimal heat?
Speaking of stackable, is it possible to get a MM powerboard without buying a new ESC, and how many power boards will the brain control befor it's overloaded?
GriffinRU
10.21.2007, 02:02 PM
Welcome to RC-Monster!
Castle Creations didn't replay on any of my e-mails, so do not know.
As far how many boards you can stack, 2 boards would be the sweet spot. Then you will create layout troubles and total gate charge of more then 24 FETs will exceed 1.25A driver ratings at 10kHz.
