david lamontagn
10.22.2007, 03:40 PM
OK Brian, my ICE charger have a CC/CV charge profile, for li-po (3.7v/cell and li-ion 3.6v/cell).
So i consider that if i select the li-ion profile, i'll be able to charge the A123 pack???
My charger can only charge 4s li-po, so it will charge also only as li-ion, so if i buy a DeWalt pack on Ebay, the only thing i'll can do is to make a 4s arrengment, right?
But can i built a 4s2p? and please, tell me the difference between a 4s and a 4s2p configuration. Is on the 4s2p i'll have twice the runtime of a 4s configuration??
Last, could you tell me what's the capacity of the A123 DeWalt pack in mAh??
Thank you very much ;-)
Ho! forgot to ask, at wich amps can i charge this pack, should i charge it at 1C like li-po cell??
David
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
10.22.2007, 03:57 PM
you can build 4s2p, or just 4s to save weight. i bought two 4s2p packs from a123, and bought two 3s1p (wired in parallel, so i can have 5s2p) from someone on ebay. building them seems easy, but i just didn't want to mess with it.
i had 2 Ice chargers as well, but it won't balance the a123's. so i sold one Ice (about to throw the other one on ebay) and bought a123's charger. it's a fast charger, plus it balances the cells.
Eflite Blade 400 heli on 3s
jhautz
jhautz's Avatar
10.22.2007, 04:28 PM
David
Actually a123 cells require a 3.3v profile. Lipo is 3.7, LiIon is 3.6 and a123 is 3.3 just to confuse things.
to make it...
or break it...
Silent...But Deadly
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.22.2007, 04:44 PM
That's the rated nominal voltage, don't forget.
Lithium Poymer (lipo)
- 4.2v/cell CV, and less than or equal to 1C charge rate (CC)
A123 chemistry (M1 cell)
- 3.6v/cell CV, 10 amps charging (4.3C) at this voltage
- Anything higher than 10 amps charge, 3.8v/cell should be used to get the rated mah into the cell.
-I don't know what the actual limit as far as charge rate IS, but I have seen these be charged at 10C (6 minutes), safely.
