phildogg
phildogg's Avatar
10.25.2007, 08:23 PM
truck looks great bro..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
cemetery gates
10.25.2007, 11:17 PM
Thanks for the compliments guys.
Question, before I was running 3s and geared for 38mph and pulled 90amps. Now running 4s re-geared for 38mph I get a little over 90amps. Shouldn't I pull less amps? I am pulling more watts though; from 700 up to 1200+...
Heres a graph; Batt holds 3.375v/cell@ 90amps! Its 15c cont. which is 63amps, 20c burst which is 84amps, so I thinks thats pretty good!... @65amps I get 3.575v/cell
So why didn't I get a reduction in amps?
Bye
10.25.2007, 11:30 PM
I think your findings illustrate what Brian is always telling me. With higher voltage input more amps will be drawn, up to a point. Not sure when this stops, or what it all means. I have a feeling thyat you had your 10l geared high on 3s and it was pulling 90amps due to heavier load. Now it is geared down it still pulls the same or more amps, but is most likely more effecient and may heat up less? The lower gearing will help the heat issue, it did for me when I went to 4s on my 10l.
cemetery gates
10.25.2007, 11:35 PM
Seems logical, With 3s I was geared with a 20t pinion, same as your crt.5 you had right? I get the same temps on the motor (145f) but the esc and batt are much lower(like 30f lower). So????????????????????????....Maybe Brian could chime in?...
Bye
10.26.2007, 12:07 AM
Yeah, the motor temps on feigaos suck, you have to gear down to get them to stay low on a long run. The batt and esc are not working as hard now as they were on 3s with the 20t pinion. Plus the motor has greater mech. advantage with the smaller pinion gear. Som educated spouting by Brian would be nice!
