Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
It is done...
It is done... - 10.25.2007, 08:55 PM
First off, a big thanks to Mike for the diffs and modified output shafts, they really are nifty little items. And a big big thanks to ClodMaxx for all his help with getting me the UE ultralite cases- life saver dude.
Thats a nice lot of parts.
Stunning quality; I was going to polish them, but there really isnt much need to be honest.
One HB 1/8 diff.
Remove 4 screws holding the ring gear onto the cup.
Remove spider gear from shaft, slide out pin & remove shaft. Replace pin into modified shaft.
Insert shaft into ring gear, O-ring seal holds it into place which is handy.
Replace spider gear onto shaft.
Remove grubscrew from diff cup, this allows you to slide out the pin & withdraw the output shaft.
As before, insert pin into new output shaft, drop it into position, and replace spider gear. Replace remaining spider gears, fill cup with diff fluid, and screw ring gear back into place.
I found that two 8x10 shims was perfect for setting the pinion depth.
Tags
bullet proof, diffs, emaxx, hotbodies, unlimited engineering
