DrKnow65
DrKnow65's Avatar
10.26.2007, 10:09 AM
I've had another thought about modding this failsafe, if I just "opened" the signal generating circuit so it didn't put out any signal when it goes into bypass wouldn't the failsafe on my esc kick in and the car go to neutral?
I still think I will persue this mod for a bit, the more I think about it the more I like the idea of having a failsafe for voltage and temperature (even if it does onlt monitor the paralleled cells).
Finnster
KillaHurtz
Finnster's Avatar
10.26.2007, 05:21 PM
You don't need to monitor Par'd cells as its not possible for them to be out of balance to ea other as long is there is a connected circuit.
Think of two standing buckets of water. Now connect them at the bottom w/ a hose. They can then only be at the same level. There is no way to keep one more filled than the other. Ie they act as a single bucket.
