sikeston34m
sikeston34m's Avatar
Smile 10.26.2007, 08:44 PM
LOL Jhautz, you're too funny man. You have some AWESOME setups.
I didn't think the Quark 33 would handle it either, but I like to experiment. It doesn't get hot enough to burn my finger though. LOL
I was running it in the grass, on gravel, cutting donuts on the wet concrete driveway, and played around climbing some 6 foot tall dirt piles with it.
It should be interesting to play with. If the 33amp esc starts giving me trouble, I'll probably put my Quark 80 back in it.
I just had to see though. I didn't think this motor would draw that many amps with the gearing used.
This motor was in a Rustler for awhile on 4S with the Quark 80. I geared it pretty high, and it was awesome on 4S Lipo. It stripped the stock tranny gears pretty quick. After the upgrades, it would get up on the wheelie bar at 40mph.
jhautz
jhautz's Avatar
10.26.2007, 08:51 PM
Do you have an eagle tree? Id really like to see what kind of power that littel thing is handeling.
to make it...
or break it...
Silent...But Deadly
sikeston34m
Smile 10.26.2007, 08:54 PM
No I don't, at least not yet. I have been looking at them and I need one for collecting data.
I noticed Novak is coming out with their own version of the Eagletree. The Sentry Data Logger. I wonder how good it is?
sikeston34m
Smile 10.26.2007, 09:05 PM
On the Cyclon website specs for the Car 2000 are:
"Power with 16 cells : 600 W continous , 900 W peak (30 seconds)
Efficiency : 89% at 16v - 31amps, Timing 4 degrees
Current: 35 A continous, 60 A peak (30 seconds)
Kv = 2093 Io = 1.7A (6v)
Dimensions : Diameter 36 mm, Length, 53mm (without shaft), weight 160g"
I figure I'm right at the rating for the ESC, but I'm slipping by with the added cooling of the fan.
I took a closer look at the winding and the magnets in this motor. It is a 12 pole stator wound like a 6 pole! Inside the endbell the magnets are extra wide. It is being operated as a 6 pole. Interesting. I would love to play with different windings and be able to record the rpm's, amp draw, etc. with 12 pole outrunners. (whisper whisper--------Direct drive E Revo)
