ncalenda
Need for Speed
ncalenda's Avatar
10.28.2007, 01:39 AM
Originally Posted by AAngel View Post
Using the inner mounting option will reduce the width of the tire which comes into contact with the ground. This will help to reduce traction roll and will make the overall tire "stiffer."
If you are going to be running on really loose terrain, I'd mount the tires on the outer rings. Just keep in mind that the Badlands aren't particularly meant for racing and they balloon like crazy. I'd try to get a set of the GRP orange foams to minimize this.
Thanks, I ended up glueing them on the outer rim. I did get the GRP orange foams but figured I would try the pro-line foam first, just to see.
  Send a message via AIM to ncalenda
