Not for the heatsink. You will want to mount the esc with some thermal (ArcticSilver) paste. So spread some on the bottom of the esc, stick the heatsink on, make sure you have clean contact that is nice and even, clean the edges. Then you zip tie it. I think sjcrss used white paste for PC's, which is not the best to use, but it does work. I used arctic silver.
