Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
tallyram
tallyram's Avatar
10.29.2007, 04:51 PM
Originally Posted by Dafni View Post
Nice, Finny.
I still have a 1950 with similar KV around... maybe I should try an MGM after all.
i am really impressed with mine!
luxury!
  Send a message via AIM to tallyram
othello
HV basher
10.29.2007, 09:10 PM
Very "cool" HV setup. Thanx for sharing all your data. Wow ... i never managed to discharge my 10s A123 pack in under 10 minutes. Grass is definitively the best torture you can put your setup through. 1700 Watt is the maximum i saw with my Buggy too. What does your Revo wheigh fully loaded?
Reason i ask is: i just finished my 3rd conversion and moved all my HV stuff (Jazz 55+Neu1512/2Y+10s1p A123) from my buggy in a truggy which now wheighs 10.8lbs (4,9Kg). I think your data should be pretty close to what i will see (after fitting a hardened steel pinion) since i geared her for 40mph.
I hope you don't mind when i post some pics and data here too. I maidened her today on concrete but was short of a hardened steel pinion so i took it very easy with a non hardened one which survived only for 4 minutes: pic of my setup, Eagletree graph, video with my broken video cam
starscream
RC-Monster TQ
starscream's Avatar
10.29.2007, 10:11 PM
I'm getting about the same temps but I'm using the CC HV110 and a 1515/2y/extra thin can and 10SA123.
I ran my G2R with 10SA123 on Saturday on a 1/10th scale track and the packs didn't dump until 28 minutes into the run.
Ha Ha
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
10.30.2007, 01:10 PM
Wow, really? I wouldn't think that 2300mAh would take you that far, but good efficiency I guess, huh? Hm. This really makes me rethink things now....
Finnster
KillaHurtz
Finnster's Avatar
10.30.2007, 03:13 PM
Keep in mind tho that a 10S pack @2.3Ah= 5s2p pack @4.6Ah (and 5S ~=4S lipo.)
It doesn't seem like its that much, but the amp draw is less than half than a "std" 4s setup so it lasts a while. Gets a bit wierd to think about, but the total energy is the same.
Finnster
KillaHurtz
Finnster's Avatar
10.30.2007, 12:36 PM
Well I weighed again yesterday and it was a portly 4.5kg w/o the batts, so I think w/ 10cells its ~5.2kg.
However, this is with those beadlock mounted maxx mashers (also taped) which are extremely heavy, and the above mentioned wing. In race trim it was weighing 3.9kg w/o batt and w/o wing on the old MM/XL setup. The dishes/CF tires are so much lighter, but the mashers are my all-around basher tire which I love. They go anywhere and are still wearing well for over a year of use.
There is one last race event @ barnstormers this year, so I'll try to get a weight when its prepped. I hope to get ~4.5-4.7kg RTR then.
Oh, and by all means post any data. I've seen some of it before, and I really like your ET-linked vids. I'm always curious to see more data.
I did assemble a little 2S A123 pack. I'm going to try and run that tied in for 12S just to see what happens. It should break 50 if I can control it. Purely for research purposes however.
