Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
othello
HV basher
10.30.2007, 09:20 PM
Neu 1521/1Y (1577KV) @35-40V equals 55000-63000rpm That is absolutely on the edge of its 60000 RPM limit. And i did worry about 40000-45000rpm ... feeling stupid right now.
So now you know how your motor operates at its limit.
lutach
lutach's Avatar
10.30.2007, 10:41 PM
It is definitely a good feeling to know it can take it. I'm going to get some special batteries that will make my 1521/1.5Y and 1527/1.5Y do amazing things. All I can say is I'll be able to use 14S of this cells in the BPP truck, but I can go as high as 18S.
jhautz
jhautz's Avatar
10.31.2007, 01:59 PM
how did you get those tapped holes like that in the edge of the heat sinks lon the MGM? Looks like a really clean way to be able to mount that thing. Id like to do that to mine to get rid of the zip ties I'm using now.
Did you drill those yourself?
to make it...
or break it...
Silent...But Deadly
Finnster
KillaHurtz
Finnster's Avatar
10.31.2007, 04:26 PM
Mine came with them predrilled, I assumed for attaching the fan option they have. They are 2mm holes, so mounting it was pretty easy. I used a little piece of plastic as a slab to put the 2mm bolts thru, then I have that attached to the chassis w/ a couple 3mm bolts. Then its secure, but easy to pop out for any reason. Plus a bit of fuel tube in between for some dampening (see, it's good for something :) .)
I didn't get any ET data, I had it w/ me, but couldn't fit it in there lol. With those extra cells and the Y to connect them, it got a bit messy. Def not for everyday driving, but just to screw around with. I don't think tho I was ever able to even draw 60A as the power was just too much. I estimate it was capable of 2100W peak, but I could never put that down w/o doing a backflip.
There were few times I could bury the trigger, but that was only once it was already going quite fast, so you just wouldn't see that big power spike like on takeoff. Didn't last long either as the front came up or the truck got unstable due to the tires and had to let off.
The tires didn't balloon too bad as they are taped, but at such high speeds they don't balloon evenly and handling gets squirrely.
