Mike_D
Mike_D's Avatar
10.31.2007, 02:38 PM
Mike - Is that a Mamba Maxx esc is see running with 18.5v lipos? If not what esc is that?
HB Ve8 x 2
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.31.2007, 05:50 PM
Yes...a Mamba Maxx that runs an occasional 5s Lipo. :)
It is typically only tasked with 4s though. :)
HBRC
HBRC's Avatar
11.21.2007, 03:02 AM
How's your pinion and spur holding up? I was just changing the diff fluid in my center diff during the build of my RC8, and I had just assumed the extra Kyosho plastic spurs from my EL8 would fit, but it's not the same dimensions.
I haven't finished searching to see if there's a compatible plastic spur yet.
Lemme know if it's even an issue, thanks.
Chris
jhautz
jhautz's Avatar
11.21.2007, 03:23 AM
Just use a hardened pinion gear from the RC-Monster store and you can run the steel spur no problem. The plastic spur is no longer needed since Mike came out with the extra hardedned pinion gears. Many folks have already been using them for a long time and they are holding up very well.
These.... http://www.rc-monster.com/proddetail...1pinion&cat=40
to make it...
or break it...
Silent...But Deadly
