crazyjr
crazyjr's Avatar
11.02.2007, 11:56 PM
According to posts by Patrik, they used stock Emaxx gearing (18/66) and 6s, with a 2200kv motor
Patrick
Patrick's Avatar
11.03.2007, 02:33 AM
Originally Posted by crazyjr View Post
According to posts by Patrick, they used stock Emaxx gearing (18/66) and 6s, with a 2200kv motor
Yeah, they used a higher kv motor than you would usually use for bashing with 6s. The 1y (2200kv) they used is a powerful motor that would be doing up around 48000rpm on 6s...good for speed runs.
They must have geared it up a bit though, because using the calculator the 1y on 6s with stock e-maxx gearing should be geared for around 48mph or so, unless they used tires with a huge amount of ballooning
To avoid any confusion, I'm not the same Patrick that crazyjr is talking about.
