podunk
11.03.2007, 11:46 PM
Thanks
spaz163
Functionality with a dash of Form
spaz163's Avatar
11.05.2007, 11:04 PM
On my Ofna MBX buggy I used 1/4" thick aluminum bent at a 90 degree angle. Worked great for the motor mount.
As for BL setup I used what I had, Mtroniks Truck ESC and Feigao 8XL motor. ALso, I am using 14 Ni-Mh EP4200 cells. But it weighs a metric ton!!! Still smokes my buddies nitro Ravager though. :)
david lamontagn
11.07.2007, 11:50 AM
I'am to convert mine, near to be done. I've take the RCM motor mount for the revo, fit very nice.
I've a Neu 1515 1Y motor with flightpower EVO25 5000mAh, 4s li-po and MGM compro 16018 controller.
I've a 12 pinion, and i've change the stock buggy wheel and tire for monster truck size tire. I've put Ofna half offset wheel and badland MT tire.
Little "bizare" look but it's a nice machine.
podunk
11.07.2007, 12:24 PM
could you post a picture of the chassis. I'm mainly curious about the motor mount and where it sits in relation to the center diff
thanks
david lamontagn
11.07.2007, 12:36 PM
I'll try to post somes pics tonight after the job. But it's the easyest conversion that i've make, it's realy, realy easy to do. And with the RCM revo motor mount, all you have to do is drill 4 holes in the chassis.
