GriffinRU
11.04.2007, 04:22 PM
Originally Posted by Serum View Post
Cool work Artur!
why not use a mamba 25 as a controller-board?
Thank You, Rene!
$80.00 for 25A looks expensive for me when you can get 100A for $135.00 and I can re-use parts from MambaMax, not sure about mamba 25.
But I don't see any problems with using Mamba 25 brains with my power boards. Once I make it to work with MambaMax it would work with all Castle family, I hope :)
lutach
lutach's Avatar
11.04.2007, 04:40 PM
Artur,
On the Schulze controller, I see the small SMT resistors next to were the MOSFET goes. If I wanted to make extra powerboars, would thee work with the same resistance or would I have to use different resistance for everything to work ok? The reason I'm asking is because I see a few controllers that stack powerboards to up the AMP rating.
Dafni
Dafni's Avatar
11.04.2007, 04:44 PM
GriffinRU, just want to let you know that this double-stacked MM still holds up great!
GriffinRU
11.04.2007, 05:09 PM
Hi Dafni,
Great, did you build one?
GriffinRU
11.04.2007, 05:06 PM
Artur,
If you noticed, I'm not using them because I have them on my power board. If you stack power boards (identical) there is no need to change resistors (but they need to be tuned if you happen to replace stock fets with newer/better ones).
So if you have two schulze controllers then you can make a double decker, like mambamax with minimum effort. But do not exceed the current ratings of the fet drivers, do the math with# of Fets, # of resistors in parallel, Rg and switching frequency. But with 2 boards you should be Ok, otherwise start sharing resistors and fight with ringing.
What's the current limit on these proto-types?
Probably PCB limited to 75A, Fets are 330W rated up to 160A at 100C
