This powerboard has 30 of the larger 80v 75amp Mosfets. This will be a hefty gate load for the drivers to carry. This is why I need to study Brain Board Components alot closer to calculate driver load carrying ability.
That is nice. You might be able to use 18S lipos with your controller. Good for speed runs LOL. Make sure all the components are rust free.
Yesterday, my Quark 80 amp died. It still blinks the red "heart beat" at the led's. It also lights different led's with different throttle positions on the controller. No power is being sent to the motor.
I suspect the problem is on the power board. I hope it is.
Can I adapt the brain board to work with this larger power board?
That's what I'm thinking about doing. It would be a 6S ESC that would kick butt.
The larger power card will do 300amp at 36 volts. That would be 450 amps on 6S.
