Did you get any extended run times with this setup? I bet the little motor works up a sweat putting out that much power. I have experienced the same concept. The little motors put out plenty of power! The problem is when racing, the heat buildup becomes an issue (I fried a basic 3100 in a race - burnt the windings!). The higher voltage should minimize the heat, but that would still be a concern for me.
