Matthew_Armeni
Matthew_Armeni's Avatar
11.07.2007, 07:09 PM
No idea on the MMM, but the MM can handle the 4S with ease. Unless you're going to eventually go up to 6S the MM should be fine and all you'll need to do is get a BEC. Or run 3S, a hotter Neu, and no BEC, that works too.
  Send a message via AIM to Matthew_Armeni
