Programming 99.18 for Li-poly? -
08.09.2005, 03:41 PM
Hello,
I want to run my Warrior 99.18 on a 3200mah 11.1 volt Li-poly pack, but I beleive I need to set it up to do so. If anyone could offer advice or help I would really appreciate it! Thanks!
-Jack Miles
2x Warrior 99.18, Hacker Master Car, 2x 7XL, 10L, 8L, 7S. 20.120!
10L's wasted by my Speed project: 2
08.09.2005, 03:45 PM
No, you only need some kind of alarm that tells you when the voltage dropped below 3V per cell. No need to program you 9918..
08.09.2005, 03:48 PM
How would I go about doing that? :C:
-Jack Miles
08.09.2005, 03:57 PM
Buy this little lipoly friend.
The problem is that lipoly get damaged when you run them under the 3V each cell (3S = 3X3V=9V)
08.09.2005, 04:01 PM
What happens if I didnt run one of those?
-Jack Miles
08.09.2005, 04:08 PM
08.09.2005, 07:35 PM
-Jack Miles
08.10.2005, 07:20 PM
looks good, how do you like the buggy? i was seriously considering getting one of them but the time it was taking for him to make them really turned me off. made me worry what if I broke something that wasn't going to be available at the LHS.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
08.10.2005, 07:45 PM
There is also the Li-saver, which causes the motor to stutter when the voltage gets low:
http://flydma.com/lithium/lithium.asp?path1=lithium
08.11.2005, 04:28 PM
I bought a Li-Saver, I will let you know how it works. It will be here tommorro and I am racing it on sat.
-Jack Miles
08.12.2005, 01:26 AM
Do let us know how it works!
08.12.2005, 01:08 PM
Hey Guys, it just arrived today. The first thing I noticed was I didnt. It comes packed tucked inside the instructions. :) The thing is very very small. Here is a comparison picture I just took. I'll put it in the buggy now, I'll post an installed picture.
-Jack Miles
08.12.2005, 10:23 PM
I'd just let you guys know this thing works great. I took it for a test run on a half dead battery, I ran for about 7 minutes when I got my first stutter. To be honest I was really nervous about this. I wasnt sure when it was going to kick in, but it did. And it did it extrmely well. At First a small stutter, then it will get a big more apparent. You'll definately notice it, but you'd still have time to get it back to safety.
-Jack Miles
08.13.2005, 03:24 PM
This is the first review I have seen on this device. It is good to know it works in case the one the LVC device I am making doesn't work.
08.14.2005, 04:56 AM
Great to hear it works allright! i will remember this little device. I was a bit sceptical about something hicking your BL setup to be honoust..
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
