Sorry dafni, its the 1/8th shaft that uses standard pinions. I've never heard of this happening, many of my friends have that size shaft and have never broke one. And no i did not have the gear mesh to tight.
What did you snap the shaft off there mike? You the first i heard of snaping a shaft of any motor. Let me know how you like that 7xl. I think you will like it. Have to learn trigger control. :)
Peace!
Country
Help support the
Rc-Monster Buy here
The 1/8" shafts CAN and have been broken. Mostly from mounting the pinion out towards the end and running a lot of power. If you want to push the performance envelope, the 5mm shaft is the reliable way to go. I wouldn't say a broken shaft is "common", but it does happen every so often( I have had 1 broken shaft and 1 bent shaft come back in the last year).
Yeah well it sucks but oh well, i ordered the 7Xl and an 18 tooth pinion, i think thats a good place to start with gearing. But maybe with this big of a motor i might be able to go up some?
Thanks dafni, i will be running 12 and 14 cell packs so an 18 tooth might be perfect then. I wont be running on any tracks nor doing any speed runs, just bashing in my yard and the street.
