rchippie
rchippie's Avatar
11.13.2007, 09:07 PM
On 2s the velineon will be slower than the mm. Plus the velineon esc does not have much (if any) programability. I have owned both and consider the mm esc to be very superior.
thank's again . i just saw the venolin motor is only 3500 kv. I'll just get the 570 MM system from my friend's store.
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
11.15.2007, 01:08 PM
i just talked with brian g & he suggested not to use the mm motor but to use a feigo s motor. He said a 7s with a 15t pinion would be good for around 35 with the kit tires. He also said if i wanted to use truck tires that a 8s with a 14t pinion would be good. He also said these motors would not get as hot as the mm motors because they have a little more torque. So im probably gonig to get a 7s motor. what does everyone think ?.
11.15.2007, 01:17 PM
Well if you do not want the mm motor, the feigao s can is a better choice. I have a stampede with a 12s on 3s lipo and it has run better than any other small motor I have tried. I have pitted it against the mm motors, the velineon motor and a few others. If you look I posted a thread that shows the internals of the mm motors versus the vxl motor. Both are smaller than the feigao s can.
I have a slightly used (2 runs) 7s motor here, If you want it send me a pm. Nothing wrong with it, just too high kv for me as I am going to 4s and higher systems.
rchippie
rchippie's Avatar
11.15.2007, 02:44 PM
Ygpm
rchippie
rchippie's Avatar
11.19.2007, 12:23 AM
I would like to post a couple of pics of my crt.5 conversion so far, but i dont know how. Can i email them to some one to post for me ?.
11.19.2007, 12:29 AM
Do you have a photobucket acct?
Sign up and you can upload your photos to photobucket and then jut copy the img code and paste it in a post. The pics will show when you preview the post or submit it. It is also nice to be able to access them from any pc too!
rchippie
rchippie's Avatar
11.19.2007, 12:33 AM
No i dont have a account there even if i did i would'nt know how to use it. Im not very computer smart.
