JPP
11.14.2007, 04:38 PM
I understand the Quark has its own issues around cooling. As to the MGM, mine was repaired under warranty (although it took 6 weeks to get it back), and I view what happened as an aberration. The big problem as far as I'm concerned is the programming issue; I'm not the only one who has had issues with that.
Let us know how it goes.
david lamontagn
11.14.2007, 08:01 PM
Why did you keep to use the Tx programming method
The USB COM is suppose to simplify the programming task alot.
And for the price of this little programing device, don't know why lot of people keep to use the Tx for programming this controler.
JPP
11.14.2007, 08:20 PM
I've since ordered the USBcom+ and will try it when I next get the chance, although I'm in essence having a problem simply pairing the device with my Tx. On a fundamental level, you have to get the ESC to recognize the end points of the Tx, no?
