UE Knucklehead Towers-FLM Hybrids
Duster_360
UE Knucklehead Towers-FLM Hybrids - 11.15.2007, 09:09 AM
I was trying to use a set of UE knucklehead towers and when I installed my flm rear hybrid bulk last night I found the knuckleheads towers will not fit - the top screw on the hybrid interferes with the bottom brace betweeen the "legs" of the ue towers and you can't get the screw hole lined up.
I want to run a wing and I have the mount (a DD mount) to run one off the UE towers. I obviously don't want to modify - cut the brace off - the UE towers.
Does anyone know if the DD wing mount will work with the flm towers??
Serum
Serum's Avatar
11.15.2007, 01:22 PM
You need to dremel a notch in the tower. I had the very same problem with mine. Easy fix though..
I also used button head screws to give it more clearance.
Duster_360
11.15.2007, 02:19 PM
Cool, I didn't think of trying a button head! I'll swap that one out and have a look to see how big that notch needs to be. Still, I kinda hate to cut on them, but it sure would solve the problem as long as the notch is not real big.
Thanks!
Serum
Serum's Avatar
11.15.2007, 02:27 PM
You can make the notch in the center, so you can't see it. I also shaved off a little bit of the bulks. It can be done invisible.
Duster_360
11.15.2007, 02:33 PM
Thats what I wanted to hear! Sounds like I have some dremel time coming up thius evening when I get home.
Thanks Serum!
Serum
Serum's Avatar
11.15.2007, 02:41 PM
Anytime.
The aluminum as used on the UE towers is TOUGH! it takes time to dremel it..
Duster_360
11.16.2007, 09:30 AM
This worked out way better than I anticipated. I did not have to touch my UE towers. There is enough meat on that top boss for the screw that after changing to a button head, I was able reshape it to fit under the bottom cross piece on the UE tower. The front bulk was done in maybe 5 min using a sharp file. Since the rear bulk was already installed and I did not want to remove it, it took longer, maybe 15min since I had to be more careful not to let the file hit anything else.
The key was changing the socket head to a button head - that changed that areas profile so much it was not that big of a deal to reshape it from there to match th econtour under the UE tower.
Thanks again Serum for pointing that out!
squeeforever
squeeforever's Avatar
11.16.2007, 03:29 PM
Just putting it out there, but you wouldn't need the wing mount for the FLM towers. They have holes already setup for a wing mount. I think a Mugen fits, as well as others.
Duster_360
11.16.2007, 04:02 PM
Thats good to know in case anyone else is considering the same kind of conversion.
I had a set of Tmaxx diffs in GA bulks that already had the UE towers, mount and wing. After being here a while and doing some reading, I didn't think Tmaxx diffs - even in GA cases with flm cups would handle the neu power to come - reason for chanigng to the the hybrids. Was kind of a surprise for the UE stuff to not fit.
I was going to convert my E-Maxx and as its wound up, I'm building a new one around the extended chassis, hybrids, 125b, neu, cvds etc.
Serum
Serum's Avatar
11.16.2007, 04:38 PM
the FLM towers don't fit that mugen wing i thought it's kyosho.
squeeforever
11.16.2007, 05:38 PM
I'm not 100% sure on which wing mounts fit it, but I'm pretty sure that at least 1 Ofna, and the HB will fit.
Duster_360
11.21.2007, 03:35 PM
In case anyone needs to know - this is pasted from FLM's site (which is finally back up!) - the wing mounts that FLM towers -
"Tower has been machined to accept GS Storm and Hot Bodies Lightning wing mounts"
neweuser
neweuser's Avatar
11.21.2007, 06:25 PM
The MBX5 I think it is will also fit, not perfectly, but damn close. Which I have (Mugen) and Serum, mine fits snugly....
GorillaMaxx360
GorillaMaxx360's Avatar
11.21.2007, 07:11 PM
use mugens on mine two but had the gs ones but they where too short for my liking.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
11.22.2007, 09:40 AM
I run Dace towers, along with the MBX5 wing mount, for the upper screw in the FLM bulks, I just went to Lowes and purchased a package of M3x.50x16 Machine screw pan head slotted (upc#008236711202) and they fit perfect, and you cant even tell that i used a flathead screw under the tower.... no dremeling or modding needed....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
