Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
11.17.2007, 01:32 PM
Ok, here's my parts list that I plan on ordering.
Towerhobbies order
Hotbodies Output Joint Cup(pinion cup)
Stock #LXJBE9 (order 2) ($3.39 each)
Note: Tower is out of stock-Ebay has them
DuraTrax Metal Set Screw Asst. 4mm (12)
Part # LXTW57 ($3.39)
THS Racing Center CVD Set Revo 3.3
Stock # LXRLN4 $37.99
2 - Hot Bodies Spiral 10 tooth pinion
Stock #LXJBM3 ($13.99 each)
2 - Hot Bodies Front/Rear Hardened Diffs (43 tooth spiral ring type)
Stock #LXLGXO ($41.99 each)
Pinion Shims
Stock #LXGPC9 ($3.89 each)
AXI 4120/14 Outrunner Motor (660 kv)
Stock #LXPPX8 ($129.90 each)
Total $279.92
RCM Order
2 - V2 Revo Hybrid Diff Cases $80 each
includes the 6mm output shaft conversions
$160 Total
As you can see, RCM's drop in Hybrid diff is alot cheaper than gathering all the parts. I wonder when he will have those back in stock? If it's soon, I will wait. If not, I'll go this way.
SuicideNeil's post is very helpful on building Hybrid diffs. Thanks Neil!!
http://www.rc-monster.com/forum/show...ht=hybrid+diff
