nl12
nl12's Avatar
11.23.2007, 08:19 AM
Originally Posted by squeeforever View Post
Those shock bodies are worse than anything. They don't really help at all. They hurt. You have to run MUCH heavier oils because the pistons aren't big enough.
Do you mean the bore is too big causing the pistons not to fit as they should? I dont understand.
squeeforever
squeeforever's Avatar
11.23.2007, 12:56 PM
Yes. Exactly the problem with them.
FastEddy
11.23.2007, 07:10 PM
This is the word on them. Many have complained about the fit.
A secondary effect of the larger tubes with the sloppy fitting pistons is shaft slop that causes perpetual leaking.
One of my buddys said that if they leaked any more then they do he would need to get them a shot of penicillin.
