ssspconcepts
ssspconcepts's Avatar
11.25.2007, 10:14 PM
One more question...what would be a safe bet for gearing on the CRT.5 assuming I was using 2S, MM, and Neu 1509 1.5D (4500kv)?
rchippie
rchippie's Avatar
11.25.2007, 10:31 PM
I dont know , because this is my first time converting a crt.5. someone else will have to answer that for you.
REAL MEN RUN BRUSHLESS
ssspconcepts
11.25.2007, 10:45 PM
Thanks Hippie...maybe Brian or one of the other seasoned vets will pick up the question and run with it.
I hope you got your wheel situation squared away (or should I say rounded away)....
rchippie
rchippie's Avatar
11.25.2007, 10:54 PM
Yes id did get it figured out. Who ever said i needed the FR wheels was right. So im going to get either traxxs rims or rpm rims. I also thought about using the B3 wheels that come with the kit. But if i do that the tire width when mounted will be a 1/4 inch narrower. I have to buy new foams because the acetone i used to soak the tires of the wrong rims split one of the foams. so im going to buy firmer foams because to stock foams were extremely soft.
ssspconcepts
11.25.2007, 10:58 PM
I like RPM rims...I use Rit clothing dye to color them to match my paint scheme...works like a charm and looks great.
rchippie
rchippie's Avatar
11.25.2007, 11:13 PM
I've been using rit dye for years .
Good News
rchippie
rchippie's Avatar
Good News - 11.27.2007, 10:18 PM
I just completed my crt.5 & took it out for it's first test run. It's a quick little sucker . They are very responseive compared to the bigger cars & trucks. So far im vey happy & excited about it. Im going to fully charge my lipo's tonight & give it another shot tommorow. Pics to follow.
What color springs is everyone running ?. I have the stock gray right know but i think i may need the blue medium springs, because of the weight of the lipo.
