mabu
11.26.2007, 02:04 PM
I gonna use a 8XL on 4s like teknorc suggested. I hope it will not go too hot
Matthew_Armeni
Matthew_Armeni's Avatar
11.26.2007, 02:16 PM
Well the motor's gonna get hot, it's a fiego But seriously, everything should stay pretty cool, but the motor will heat up. I suggest Mikes motor heatsink clamp, it's pretty awesome and fits with the Tekno mount. And if you're really worried about temps, just buy some fans and put them on the motor and ESC.
  Send a message via AIM to Matthew_Armeni
mabu
11.26.2007, 02:41 PM
I know - i already run a 8L in my EMaxx ... it gets hot all the time.
I already ordered a motor heatsink clamp :)
Well i read that the maximum length with the tekno mount is 74mm, the length using the heatsink is about 76mm
Matthew_Armeni
11.26.2007, 05:36 PM
Trust me it fits, it's what I am currently running. You just can't run the motor in the low cg mount setup. By the way, are you running the extended rear a-arms?
mabu
11.27.2007, 08:57 AM
No, my used revo had rpm arms ...
