Serum
Serum's Avatar
08.15.2005, 04:16 PM
I would personally use a UBEC with teh 9920 if you are using it on 24 volts! the BEC will suffer from this high voltage..
@sneeck; The new 9920 has got all the wires double, (input and output) you need to connect both wires of one phase to one plug
The way you drawed is good, but i would personally use a seperate receiver pack or a UBEC..
