BL-Power
BL-Power's Avatar
11.28.2007, 11:40 AM
If you want to run on a track, it's nearly impossible to control your setup. I would take the 5700 or better the 4600 on 2s Lipo.
 Send a message via ICQ to BL-Power
Chapito
11.28.2007, 03:19 PM
BL is definitely correct! A 5700 on 3s would be ridiculous. I ran a 5700 on a 4200mah 2s geared 13/46 and it had way more top speed than necessary for racing. I'd recommend either 2s or a motor with a kv around or slightly over 3000 for the 3s. A standard size motor works alright but runs a tad on the warm side. An "L" motor on 3s is actually alot better suited to the size and wieght of the truck.
