well for the neu motor. is the higher price tag worth it, or should i just go with a feigao? either way i will be running a mamba max esc and probly both a 3s and a 4s lipo packs
Well the question is it worth it to you? To me, a guy with a limited budget, it's not, at least not yet. To many others, it is. Read around and weigh the benefits for yourself. Either will do better then a VXL setup.
If you run the Mamba on 4s, make sure to use a BEC. If you want to run 3s, the Neu 1515/1.5D is the best choice of motor we used. A Feigao 6XL should work too. It is recommended to go 4s though as some have suggested.
The Neu's are definitely worth it IMO. You get what you pay for. That said, the Feigao's can't be beat for a value motor.
