squeeforever
squeeforever's Avatar
12.01.2007, 01:32 AM
Jhautz might be onto something with the battery tray idea. Best guess for size would be around 50mm wide, maybe 52mm. Length, not really sure.
jhautz
jhautz's Avatar
12.01.2007, 03:12 AM
Seems to me the most popular lipo sizes out there are the enerland size cells and the Max Amps size cells which are both 45-46mm wide. If you made it fit a 166 mm long battery it would fit the enerland based 5000mah packs and the Maxamps 5000 packs. (as welss many other of the pack sizes) The maxamps are a little shorter and thicker but it would still work.
Another possibility would be to have the back of the battery tray be a separate piece that could be adjustbale for the battery lengeth and held inplace with the screw that holds the strap down.
to make it...
or break it...
Silent...But Deadly
