ssspconcepts
ssspconcepts's Avatar
12.02.2007, 12:06 PM
OK thank you Serum for the diff, you'are right, it's a Spyder diffs, and it' bulletproof, but you not tell me why you said that clutchbell is unecesary on a brushless....
The main reason why i want a clutchbell, is when i land a big jump, i want that the clutch (and not the motor) take the big "spin" of the center diff when the wheel touch the ground.
When you hit the brake in the air to "nose down" the buggy, the wheel stop to turn, and when the buggy hit the ground, the wheel re-start to spin and give a big "hit" to the motor, so with a clutchbell, you eliminate this problems.
My goal is to make it very reliable.
And if i don't like the clutchbell system, i'll simply re-instal the right motor mount for the buggy and return to a standard pinion/spur setup.
And more easy, the tekno Electri-clutch have a 5mm shaft where the clutchbell bearing, so i'll can leave this in place and simply put the standard pinion on the tekno elektri-clutch adapter.
The clutch increases the overall rotating mass of parts that the motor will have to turn...and therefore places additional strain on your motor. My preference is to keep my setups as simple as possible...Keep It Simple Stupid (KISS)...just another American slang term for you to put in your toolbox...
david lamontagn
12.02.2007, 12:30 PM
You're right, but please, the little extra "strain and rotating mass" of a clutchbell setup, on a Neu 1515 motor, who normally can push a 13lbs++ monster truck over 50m/h, will not (this is what i think, correct me if i'am wrong) place a big "stress" on the motor on this little 7.5 lbs 1/8 scale buggy
+++++I don't have to buy the RCM revo motor mount, i'll simply use my RCM Mugen motor mount, and place it just behind the stock center diff mount.
I just try it and it work like a charm
Now i must absolutly take the Mugen MBX5R.....sorry RC8another time for you!!!
david lamontagn
12.02.2007, 01:31 PM
I don't know what's this mean, i'am married with 3 kids
