Size Matters.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Size Matters. - 12.03.2007, 02:18 AM
Of course most people believe that size matters, and for the most part that is true. If you use the right materials then the larger you go the stronger it will be, but all three of them will hold up if they are of metal construction. With increased power you need to install a metal drivetrain. Your truck looks like a pretty good build, and seems to be tuogh enough, but how many real size vehicles do you see on the road with plastic parts used in the chassis or other structural parts. Plastic is only used for cosmetics, not for strength and support. If you want to have a vehicle that will take almost anything you throw at it, then you have to go metal all the way and build in soft points to absorb impacts. Plastic will break no matter how careful you drive. Sooner than later you will hit something and break the RPM gear and if you have a weak drivetrain it will break as well. Especially if you have brushless power under the hood. 10 to 15 lbs of metal and plastic going 30 to 40 mph will cause some damage. If you want it to last build it from steel, aluminum, and titanium. If you travle around through this forum that is what you will see in the ultimate vehicles by the people who want their trucks to be bulletproof. Good luck with that.
12.03.2007, 10:37 AM
let us kno how that motor goes, ive been lookong at it. in your guys' opinion, is it better than a feigao 9xl?
tashpop
12.03.2007, 10:01 PM
its crazy powerful. there's a thread in the brushless forum i started about it. look it up.
PhaedruS
12.13.2007, 11:42 PM
Hey Tashspop. I'm popping over from the BYT site for a bit. I have experience with many types of hub setups. If you have a lot of 14mm wheels and want to make that work better, then this is the best option I know, and they are only $9:
https://host446.ipowerweb.com/~acncm...ddc9f86fbe65ff
I have used the above 14mm hexes on my supermaxx, savage, and .21 maxx with absolutely no stripped wheels once I converted. None of those had BL power though...
I have the Dace 23mmm setup on my Revo and LOVE it. I keep a 22mm socket wrench in my bag just in case, but I have never lost a nut or even loosened a wheel to date. ACNCM also has a 23mm kit, but I have not tried it. I have the Dace set running on top of stock plastic Revo hexes, but the Dace configuration grabs the heck out of them so there is NO slop or spinout. Bear in mind your wheel selection and bake off your old wheels to savce another $50. I just boiled off a set of Zombies and reglued them to 23mm wabash white rims for the Revo.
