12.04.2007, 08:13 PM
And you generally don't parallel regulators, but use a higher power/current pass transistor. But no matter how it's done, a linear regulator is inefficient, especially as the supply voltage and load current increases.
That said, a linear regulator works well in the 2s (maybe even 3s) or 6-8 NiMH cell range. Since the voltage is so low, efficiency is close to a switching UBEC.
sikeston34m
sikeston34m's Avatar
12.05.2007, 01:26 AM
I decided to go with Castle Creation's BEC Switching Regulator on my E Revo.
It looks like a pretty good setup. On 4S Lipo, it should help to take heat/load off the ESC even after I install the 125 Amp Monster Pro.
http://www.castlecreations.com/products/cc_bec.html
Anyone had any experience with this one?
I know JohnRob did a pretty impressive video with it.
