MetalMan
MetalMan's Avatar
12.06.2007, 02:54 PM
My original plan for my CRT.5 was Neu 1506/1Y (3600 kv) and 3s 4000mah 20C Lipo. I was able to recondition my Feigao 9L (kv ~2700), and am currently using that on 3s 4000mah Lipo with great success.
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
12.06.2007, 03:42 PM
I don't own one my self but Neu's and MM have issue's from time to time. Cogging!!!!
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
GO-RIDE.com
12.06.2007, 06:15 PM
MetalMan, I've been looking for a Feigao 9L for my CRT.5. Where do I find one? Also, what pinion are you using with that motor? I currently have (2) 12T and (1) 13T. I would like a motor that would run well with those at least until they are worn out.
Thanks
E-8ight - Tekin RX8 2000kv/4S
MetalMan
MetalMan's Avatar
12.06.2007, 06:53 PM
Thanks
I haven't looked around for any place to find them, so I'm not totally sure. However, there are some really inexpensive motors on Tower Hobbies that would run similarly:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLXA0&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXLWZ7&P=7
The first one is closest, but the second would also be a good choice (geared appropriately, of course).
I'm using an 18t pinion with stock spur on my CRT.5, on 3s Lipo and 2.2 Truck Step Pin tires (~4"), which gives a top speed of roughly 40mph. IMO, this gearing is perfect for what's on the truck (nothing overheats).
Originally Posted by steve050773 View Post
Seems I just solved my dilemma with ... drumroll... None of the above!
Just got off the phone with a Neu distributor and he had a 1506 1.5y which he stated was the same speed as 1509 1y. I've never seen a 1506 1.5y listed anywhere, but it was a decent price so I'm going to give it a shot. I'll post updates later!
That motor should work decently... Especially for a lightweight setup (although should work just fine in a regular weight).
GO-RIDE.com
12.06.2007, 07:13 PM
Thanks for the info on the Ammo motors MetalMan. Those sure are cheap. I guess I'll have to start driving my crt.5 a lot to wear out my existing pinions before switching over the 5mm.
Thanks again.
