MGM 16018 Cutting out at 1/2 to 3/4 throttle
Finnster
KillaHurtz
12.08.2007, 09:29 PM
NP, but you may want to get a separate LVC in the future. You can run the lipos lower than you mean to fairly easy, and they are an expensive investment to ruin. Too bad the on board one didn't work a bit better for you.
Finnster
Find all posts by Finnster
2
david lamontagn
12.08.2007, 10:33 PM
In race mode, you don't have any LVC i think
But in "batterie type", just set it to 4 li-po, and the controler will set the LVC automatically.
david lamontagn
3
bluesilver
12.09.2007, 04:02 AM
If I set it to 4 Lipo won't it cut out at 12V?
I am only running 3s
I take it then that in race mode it will basically keep on going untill the battery in dead flat. ( no 9v cut out)?
bluesilver
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
