Patrick
Patrick's Avatar
12.09.2007, 10:47 PM
I've had 2 quarks that a motor wire has fallen out of. Maybe check that all the connections are still good. Did the motor look like it was trying to move or just do nothing at all. If you didn't notice it before I wouldn't test it again until you know all the connections are good, it could damage something.
mabu
12.10.2007, 07:48 AM
The connections are all ok, the motor tried to do something.
Yesterday i removed the clibs i had used on the motor wires - now the problem seems to be solved...
Patrick
Patrick's Avatar
12.10.2007, 08:19 AM
If the motor moved, but didn't spin, then it sounds like 2 wires are ok and the 3rd one has an open circuit somewhere down the line.
What do you mean you "removed the clibs i had used on the motor wires" ? Did you remove the plugs and solder the wires instead?
mabu
12.10.2007, 08:26 AM
I used cable clips to bind the motor wires together - just to clean up all the wires...
May be i should solder the plugs once again too ... just to be sure that these were not the real problem!
Last edited by mabu; 12.10.2007 at 08:27 AM. Reason: added image of cable clips ;)
