12.10.2007, 12:04 PM
If you go to sdp, make sure that you select metric unit on top of the list when you are in the online store. Then go to spur gears and select 6mm for the shaft size. I have an 18 and 20t pinion from them and they are nicely made.
BL-Power
BL-Power's Avatar
12.10.2007, 01:50 PM
Ah, ok thanks! I was very surprised by the uncommon sizes, until i've seen that they are measured in inches.
 Send a message via ICQ to BL-Power
