Serum
Serum's Avatar
12.10.2007, 12:18 PM
Too bad the maxamps packs are not delivering the power you need; you might contact Jam on this forum to help you out.
Have you got an eagletree that can monitor your packs voltage?
the better the battery, the more it will be able to hold the voltage under a high load.
The race-mode might seem to help you out, but it's not a solution. You might be able to drive it, but it's killing the lifetime of your pack.
Like Finnster said; if you run the LVC at 4S on 3S pack, it works the other way around; it's better to put it to 2S than to run it in race mode. Both are not adviced though. They pack you are using is not up the task, perhaps Jason from maxamps can help you out.
