12.14.2007, 02:06 PM
You can use brians calculator - see sticky but i would start with something in the 12-14T range - You need a mod 1 pinion.
I would just get a 5mm pinion and use the 5mm to 3.125mm adapter that way you can use the pinion on other projects.
PS i used the 4600 for a while with no issues but some say that is too hot so just what the temps on the 5700.
Rgds
