BL-Power
BL-Power's Avatar
12.17.2007, 02:21 PM
What did you think of the fun 600/15? Was it a good motor, better than a feigao? I am sure that the neu is better than the kon and align motors.
I think that the Kontronik Motors arent much better than the Feigaos. My one was running very hot if i just geared up a little bit. I wouldnt buy them again, they have 3 times the price of a Feigao and they are not so much better. What do you think of them?
 Send a message via ICQ to BL-Power
12.17.2007, 02:24 PM
Interesting, thanks for the test info. I was going to try a kno motor, but if they are not that much better than a feigao there is no point. Just wondered. I do have a jazz 40-6-18 esc that i will use in something, maybe with an aveox 1300kv motor on 6s lipo! In a 1/8 scale buggy or similar size/weight vehicle. We will see if it holds up!
BL-Power
BL-Power's Avatar
12.17.2007, 02:50 PM
A 40-6-18? Do you think it can take it can take the amps without thermal issues? I think its a bit too small, i am using this Jazz in my MiniQuake
12.17.2007, 04:10 PM
You may be correct. I will first try it in my tamiya m03 fwd chassis. I have a hacker b40 18s (2600kv)motor and will try 4s lipo and see how it does. I have been using a quark 33 in the m03 with a 4000kv 380 size motor on 3s lipo. The kontronic/hacker combo should be better! A jazz 55 would be better in the buggy and would let me run 7s lipo with no issue thru the 1300kv aveox motor
BL-Power
BL-Power's Avatar
12.17.2007, 04:17 PM
Yeah, a Jazz 55-10-32 would be the perfect ESC for your buggy
12.18.2007, 11:05 AM
so i should go with the jazz 80-6-18? what motor if i run 5s lipo would be the BEST?
