squeeforever
squeeforever's Avatar
12.17.2007, 04:07 PM
Go quark, or the kontronic. The MM will not run the align 600, or any other outrunner(save for crawler apps). The quark works well for me, I actually used the roadster 65 on an align 600l in a 2wd emaxx. I would say that if you are going to run 5s that you could use the quark 80 or a mgm 90 amp esc to save some money. The align motor will not spin very fast on 4s so you will have some high gearing, and most likely need an esc with over 100amp rating. I ran my emaxx on 4400 5s 20c lipos and they stayed cool, as did the quark 65 and the motor. It was geared for around 40mph.
If I'm not mistaken, the MM will run outrunners.
12.18.2007, 11:59 AM
Yes the MM will, but not in a high load/high rpm application. It did not like the align motor and have seen it have issues with small outrunners in crawlers. I actually played with the programming on my friend's crawler and made it better. But it would still stall the motor sometimes and not be able to turn it over. I have had much more success with quark controllers for outrunner applications.
12.18.2007, 12:02 PM
whats an ideal motor for the jazz 80a esc on, say, 16 cell nimh or 6s lipo for a e-revo?
12.18.2007, 01:29 PM
About 1600kv on the motor, maybe a 10-11xl feigao.
BL-Power
BL-Power's Avatar
12.18.2007, 04:44 PM
I was using a Jazz 80-6-18 with a Feigao 11XL on 6s Lipo in my HB LSP Truggy and this combo worked great
 Send a message via ICQ to BL-Power
