starscream
RC-Monster TQ
starscream's Avatar
12.20.2007, 11:01 PM
I have experienced the same lurching after a fast run down the straight...
neither of the diffs should have any affect with coasting though so I have found it difficult to identify as well.
The diff's should mostly only affect on power handling. Any lurching would seem to indicate either binding somewhere in the drive line or the esc/motor braking. I used a metal pinion and it was eaten up after just two runs (Metal to Metal). I just picked up some hardened steel pinions today, from Mega Motors, so I'll let you know how the hold up and if the lurching issue is resolved. I am also working on a very simple plastic spur solution so I'll report on that as well.
Ha Ha
12.20.2007, 11:36 PM
The coasting issue might be due to the addl weight of rotating components compared to a similar sized electric vehicle. Do you have any drag brake set in the esc? What motor/esc combo are you running?
GO-RIDE.com
12.21.2007, 11:23 AM
Drag brake was my first thought too, but the esc is set to zero.
I'm running a brushless Novak GTB esc and 6.5 motor.
I think I'm going to try setting the rear diff to 500 to see if that frees up the rear for better off power cornering. If that helps I'll try the front diff at 1000. I'm hoping to keep the center at 3000 to maintain good power transfer from the motor.
I'm really new to the oil filled diffs, so I'm just guessing.
E-8ight - Tekin RX8 2000kv/4S
GO-RIDE.com
12.21.2007, 11:19 AM
There's definitely more drag from the front diff than from a 2wd vehicle with no front drive mech. When ever you have drag or braking from the front wheels you will have more weight transfer to the front than a Rwd vehicle. I hoping that by lightening up the diff oils I can reduce drag and get a better off power corning vehicle, but I don't want to loose much of the good on power handling it currently has.
I'm using a hardened steel pinion. It shows very little (if any) wear, and is properly engaged with the spur.
Keep us informed on your plastic spur. I am tempted to try that, but the hardened pinion is so easy and reliable.
