BL-Power
BL-Power's Avatar
12.22.2007, 09:32 AM
Originally Posted by aqwut View Post
They are built with 4 and 6 poles
I asked Plettenberg and they told me that the Maxx has 4 Poles and the BigMaxx 6 Poles!
 Send a message via ICQ to BL-Power
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.22.2007, 11:42 AM
Right on...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
skillx
skillx's Avatar
12.22.2007, 01:21 PM
I have been running my MM/BigMaxximum setup a little over 8 months now with no issues. I think from what I am reading your issue may be with the connecters. Try cutting the connectors completely out of the loop by hard wiring the ESC to the motor and see if the cogging issue persists.
My 2 Cents...
aqwut
aqwut's Avatar
12.22.2007, 03:10 PM
Originally Posted by skillx View Post
I have been running my MM/BigMaxximum setup a little over 8 month now with no issues. I think from what I am reading your issue may be with the connecters. Try cutting the connectors completely out of the loop by hard wiring the ESC to the motor and see if the cogging issue persists.
My 2 Cents...
Cool.. I did not know this was possible.... that's sweet....
Thanks guys
ilpufxit
ilpufxit's Avatar
Thanks guys - 12.22.2007, 06:20 PM
I'm going to try hardwiring first. If that still isn't it, I'll try the Quark. I was really hoping to run the MM since I have an extra one. Any input from other MM users on the best settings?
jordan...
one.five.two.seven
12.23.2007, 12:25 AM
how many cells are you running with that setup skillx?
skillx
skillx's Avatar
12.23.2007, 01:31 AM
4 now because I have a newer MM. But when I had an older MM i ran 5 all the time with no issues.
