sikeston34m
sikeston34m's Avatar
12.22.2007, 03:27 PM
I've never ran 20C Continous packs actually. There's alot about a High C Rating that is over kill IMO. I've always ran 10C Cont. 15C Burst cells.
When the Direct Drive E Revo was being tested. It was put on 6S 4000mah 10C Continous 15C Burst 4000mah packs. This was the first time I could really tell that I was pushing these packs too hard. They didn't puff, but they did get really warm (115 degrees or so).
I ran some 15C Continous 20C Burst 4000mah packs in my E maxx with the Custom Wound Motor. At 4S, I could tell they were more than up to the Amps I was pulling. They seemed to hold the voltage higher, run cooler, and also when they were done, they dumped pretty quickly.
This next round of Lipo's are 20C Continous 25C Burst. The 5000mah packs will go 100amps Continous, 125amp Burst. But they are more expensive. They all have the 45mm x 140mm foot print. This seems to fit the majority of compartments that were designed for 6 cell Nimh/Nicad packs.
The 10,000mah packs I have, also have this 45mm x 140mm footprint, they are just thicker. Also being made from 10C Cont. (15C Burst) cells, they have huge amp delivery. At 100 amps Continous with 150 amp Bursts, they can power just about anything. All done with a 10C cell. They are bulky and have more weight, but that's the price for the added Capacity.
I can now design just about ANY Lipo Pack. I wonder what the most popular design is for us MT guys?
Alot of Trucks only have room for one pack. This is where Lipo's such as 5000mah 20C 5S packs would be favored. Still doing my research on this.
I wonder what the current limit is on the new Traxxas Connector?
12.22.2007, 04:54 PM
well by revo i mean use the revo axles and make a 100% custom chassis and center. my dad will soon be getting a mill so i will be able to build it. the design will be similar to cabbie's ruggy on truggyracers.com. (except direct drive outrunner brushless powered, no center diff, and use 2 2s batt packs in series, instead of a fuel tank. )
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.22.2007, 10:53 PM
Psssshhh! Nonsense Sike!
sikeston34m
12.22.2007, 11:14 PM
OK OK, Not counting the A123's
LOL
