BP-Revo
BMW M Power!
BP-Revo's Avatar
12.23.2007, 11:49 PM
I think this is typical of a 4wd vehicle. Both my 18T, G2R, and CRT .5 do this. I find the easiest way to cope with this is to always give some amount of throttle. Even just enough for the ESC to register is enough to prevent a significant amount of the "drag" brake.
GO-RIDE.com
12.24.2007, 01:02 AM
I've been thinking of turning up the throttle center position until the truck creeps forward even at zero throttle. This should help when coasting into a turn. I've heard of an esc that allows you to do this but has a sensor override so that when the car does come to a stop under braking it will allow the car to go to true nuetral.
E-8ight - Tekin RX8 2000kv/4S
BlackedOutREVO
12.24.2007, 01:04 AM
Id just put the throttle trim up so it coast's more, but not enough to actually go when your not on throttle
