stampedeproject
stampedeproject's Avatar
12.25.2007, 04:24 PM
The Nitro Powered Yusa Project Buggy
Of course we needed a nitro powered buggy control for our little experiment. Just to assure I didn't have any screamers in the group complaining that I used some under powered mill, I installed a beast of a motor.
Obviously a .21 is the standard buggy, but I used a factory .26 Hot Bodies motor to give the Nitro version quite a bit more extra power and HP. Some will notice I swapped out the spin to start adapter for a pull start. No, I am not a masochist, the mill turns over pretty easily and I hate caring around a spin start unit or starter box everywhere I go. I found a Sportwerks Buggy body on clearance for around $10 and made the modifications needed to make it fit. The steering servo was the same Tower Hobbies eBay special that was installed on the other buggies and a Hot Bodies unit takes care of throttle and braking duties.
flyingn
12.25.2007, 05:06 PM
sweet... Looks like a sportworks clutch too.:)
stampedeproject
12.26.2007, 11:50 AM
Nope. That's the entire engine and clutch assembly from the a dual engine Hot Bodies GTX2 and holly cow it's freaking insane, I can only imagine yours with that Infinity .27. It does need to go up a tooth or so...and the split clutch unit kinda sucks. I'll probably just use the included Yusa clutch assembly. After about 20 minutes doing some tuning,I ran it yesterday around the golf course behind my house in the hard pack snow and had a blast.
Also notice the extra cross lines I milled in the head. As I was overhauling the engine for the re-build I figured why not.
