Patrick
Patrick's Avatar
12.27.2007, 11:34 PM
If they do make it shift automatically it would explain why the new e-maxx's only come with a 2 channel transmitter.
When it was first found out on the traxxas forums about the 2 channel tx people thought traxxas was being cheap and you'd have to buy the 3 channel tx that came with the old e-maxx if you wanted to have 2 speed later on. Auto shift sounds better.
Hopefully it will have some sort of soft engage. It's not as important with the stock motors, but when I used my brushless maxx with 2 speed I had to let it coast for a while before shifting to second, and even then it would sometimes make a crunch noise from the drive dog.
12.27.2007, 11:53 PM
Well, Traxxas could used the signal from the sensor to tigger the controller to momentarily interupt the throttle signal to the esc, thus killing the power for a second while the tranny shifts. Kind of like how traction control or manumatic trannys work in full size cars. Not sure if that would cause issues with the esc or motors, but would allow the tranny to shift without full power thru it.
sikeston34m
sikeston34m's Avatar
12.28.2007, 12:15 AM
What if the sensor just sets things up to shift to 2nd gear, then you have to blip the throttle to change to 2nd?
That would be cool and easy.
