chumanji
12.28.2007, 12:08 AM
Is the Kyosho spur a direct fit into the losi diff? I also notice that the RCM's motor mount has the motor behind the steering servo. Is that better for weight disturbution? There seems to be so much room on the other side...
Do you guys run mechancial brake or use the motor.
Originally Posted by starscream View Post
I'd recommend a steel 13T pinion, a Kyosho 46T plastic spur, and Losi8 Motor mount from Mike.
I'd also recomment using a plastic case to mount your lipo's in and attach it to the chassis with velcro and velcro straps.
I don't like to permanently mount batt cases to my cars as I like to use A123's as well and they don't fit in regular cases.
